maco
    56
Everything posted by maco
  1. Help! anyone I have a Zero kit car that I am finalling getting round to sort out the wiring. The engine and switches are from a 1988 Sierra. I have wired it up the best i can switching the live side of the sytem which the supplied loam suggested. I keep reading on the forum about ground switching. I have problems with my circuit and i am wondering if i have used the correct method. The RHS column switch has a number of the contacts linking to one of the fixing screws in certain switching modes which puzzled me. I connected this direct to earth and was blowing fuses so this was soon
  2. Thanks for your comment I have tried most combinations without success can you tell me when pin "W" on the RH column switch comes into action as I cannot find when it is used. The problem is as I see it is that I need to feed the LH switch 56 when the light switch is at the Top and not when in the middle or at the bottom.
  3. Hi Help I have a problem with my zero kit car wiring, I have everything working flash main beam, Dim Hazards, Wipers, ect but when I connect the washer (as the attached drawing) it will not switch off. If I remove wire 53a from the RH column switch and connect the washer it works fine from the push button but then the dip and main beam will not work. I have tried to understand the switch even got a second one thinking that was the problem and have checked the circuit a number of times but cannot find the solution. Something is obviouly incorrect. I have attached a couple of drawi
  4. maco
    Wiring Loom
    hey guys i have finally got back to trying to finish my zero after 2 long years of sorting other things out in my life . im at the stage of doing the wiring and im so confused where to start which wires connect to the column and dash etc etc .................. can anyone here help me please
  5. hey guys ive made a boob and ive drilled the holes in the top flat panel 50mm gaps in between them and when i placed it back on the back panel the holes dont even land on any of the tongues if i driled some more holes on the sides so there was 25mm spaces would that be able to pass the iva ? help Matt
  6. hey mark so when i ive completed the top of the back panel should i rivet it to the T bar that the feul tank is sitting on first the drill the holes in the side ? cheers Matt
  7. thank you john that has help me alot and alot more positive in doing the job cheers Matthew
  8. can i ask tho ive notice on me stainles steel back panel that there is excess at the bottom did you have to same and did you cut it off ?
  9. hey thank you ive debured everthing and even got the dead centre but im glad i asked cos i was going start at the bottom riveting it to the bottom of the chassis oppps guess i was wrong i should hopefully have it done soon thank you very much
  10. hey guys Im at the stage of fitting the back panel on :S i have a rough idea of doing it but would like to make sure Im doing correctly . don't really want to get it wrong could anyone help me ?
  11. chees grahem yeh i making sure i only do it once so it can passed the sva matt
  12. another question about the reverse and fog light you get a bracket for each of them do they go on the out side of the back panel or the inside of the panel ? can anyone help me ?
  13. thanks guys i can put them in now with confidence they are right lol
  14. hey im trying to get my head round put the drive shafts in correctly which side does the left hand nuts on the end of the shaft go the passenger side or drivers side ? thanks in advance
  15. ooo thats great ill give you an email now
  16. hey just wondering are they still up for grabs cos i would gladdly take them off you for £250 thanx matt
  17. maco
    Witch Way Round
    hey im put the suspension on the zero ive got gazshocks but not sure which one to put on the back or on the front the shock models ive got are the 120/085 and 140/095 any ideas guys thanx matt
  18. maco
    Bolts
    hey make sure u file down the edges of all the panels or it will take you powder coating off just to let ya know lol well if ya ever need any help with the build cozzy i will gladly help ya out also if ya want ask question about things there this and also the nottingham and derbyshire have a meeting together every first weekand in each month if you fancy come up? thanks matt
  19. maco
    Steering Column
    ok ive now managed to get it shorter but im abit puzzled on how to attach the steering colum to the chassis and im not sure if im missing something lol so guys can you post how you atched it to the chassis if you have and pics tht would be great help thanks matt
  20. maco
    Bolts
    thanks mate will have alook but i think me dad is going to order them from his works suppliers lol not sure what there called but probably abit cheeper aswell lol thanks matt
  21. maco
    Bolts
    hey cozzy no i havent started on either of those yet lol ive been sorting out all the suspension and bolts thts im not happy with a.k getting new bolts and i need to deber or want ever its called to give enough room for the spaces to go through the top hats lol and also make new spares for other areas rather than sticking washers in lol but where abouts are you in the build ? you sound abit ahead of me lol did you get yours powder coated or did you paint it like i have lol thanks matt
  22. maco
    Bolts
    im not sure ive got to have a look in the screwfix book if they do the lengths i need first ill let you know lol thanks matt
  23. maco
    Bolts
    yeh in my pack there isnt enough bolts the washers are rubbish and the quality of the bolt aint very good apparently me dad said there going to rust very quickly so we going to be buying new ones aswell lol probably from screwfix lol lmao thts the hoody way matt
  24. maco
    Steering Column
    hey yes it is a sierra column lol thanks for repling i wouldnt of relised tht and would of just cut some off lol thanks matt
  25. maco
    Bolts
    hey did everybody when starting to put the suspention together realise that the bolts was way to big for the places they was suppose to be? or is it just me matt
