wanderer
Everything posted by wanderer
  1. cant remember off hand but there is a dimension from top of windscreen to the roll bar if yours is this then the 2b roof will fit i think i must have got the measurement off here i would do a search
  2. made a strong bracket and fitted sensor to diff bolts
  3. the 90bg stalks are wired differently than the 83bg do a search on here for the wiring
  4. years ago the north west group used to have a monthly meeting at the phantom winger just off the m6 m55 junction
  5. It was on nwkcog site but also on Robin Hood kit car Facebook page
  6. One for sale in Somerset on Robin Hood kit car site presume that's near enough
  7. I have put the from borg and beck from rimmers URF000122BB
  8. They must have them hid in one of their storage containers
  9. It had the proper locating pin and didn't look the same only saw photo once and can't find it anymore
  10. I have seen a photo of Chris's gearbox looks different to mine also consider his is the turbo engine
  11. think you need to move the gearbox back by at least 75mm to get it out i will have an idea when i put mine back in if its possible
  12. mines going slow been a bit unwell will send some photos next week, i have bought the borg an beck clutch from rimmers urf000122bb also new timing belt tensioner and timing belt £130.74 including vat and delivery
  13. colin ushers now an archived file it was called Front Page if you know how to access them, i have it on my laptop but no idea how i found it
  14. very strange im booked in at the Goldcup meeting Oulton Park that weekend
  15. Hi Alan i have the engine and box out removed starter motor to take photo i am thinking of modifying the box keep looking at solutions on line,did you get a response from Redspec on how he did it although i dont fancy putting a sierra clutch in and redrilling the flywheel i have looked at Wick12 post from July 8th 2005 and may go down this route, saw your post last week reclutch arm mine is different more square i will confirm with you what clutch is fitted to mine but pretty sure its a Rover one
  16. Hi does this look right i only have about 2mm play before release bearing touches the springs with the clutch lever fully back
  17. join nwkcog run by Trevor Harmer on facebook does plenty around liverpool and wales also nationwide if you want to travel
  18. Hi Tony why dont you apply for area secretary for the Dorset and Hampshire area its not filled at the moment
  19. you would have too also change the name to The Sottish Kit Car Club
  20. mines just held up with a piece of timber across the bottom tubes with an upright the right length with a groove cut in to go around the center piece of the bonnet
  21. looks nice hope to see you at stoneleigh if on
  22. you say its a s3a are you sure? looks like a 2b to me
  23. great looking forward to your updates sounds complicated
