Cozzy
    15
Everything posted by Cozzy
  1. Cozzy
    Steering Column
    Hi Nigel. Ok, thanks, but the shaft appears to be about 2.5 inches too long, even when its pushed back toward the steering wheel. I'll put the wheel on and take a look then. Can't do it immediately i'm waiting for a new direction indicator cam bush thats on order. I'll let you know the outcome. Thanks again. Roy.
  2. Cozzy
    Steering Column
    Hi Chris, Thanks for that, i WONT cut the shaft! Thanks again, Roy.
  3. Cozzy
    Steering Column
    Hi Nick Yes its an adjustable one from a 1990 sierra. I'd like to take a look if thats ok, im on nights so its a bit late today to come over, but could call maybe tomorrow? When are you available? Thanks for that mate. Cheers Roy.
  4. Hi Folks, can anyone tell me, excuse my ignorance, when fitting the steering column to the chassis and connecting up to the rack with the GBS steering shaft, my inner shaft appears to want shortening. Before doing this, does the inner (triangular) shaft want pushing rearward toward the steering wheel, or forward toward the front of the car before cutting? Any help here would be appreciated? Thanks, Cozzy.
  5. Cozzy
    Bolts
    Hi Andrew. Thanks for the bolt matey, got it this afternoon. Pedal box fitted and ready for action. Thanks again mate! Cheers, Roy.
  6. Cozzy
    Bolts
    Hi Yanto The definition of an 8.8 spec bolt is " a bolt with a UTS (ultimate tensile strength) of 800 N/mm2 and a yield stress which is 80% of this. Basically use anywhere where there is liable to be any possible stresses or shear forces. (eg. Steering and suspension components. Cheers Cozzy.
  7. Cozzy
    Bolts
    Hi Matt, thanks for the offer mate, and the advice, and yes i must come to the meetings. Thanks again. Roy.
  8. Cozzy
    Bolts
    Hi Paul. Good advice matey. Thankyou. Im on with the panelling now, so what better time. Thanks again, Cheers Cossy.
  9. Cozzy
    Bolts
    Hi Matt. Im still early in the build. I think you are ahead of me. Now i'v sorted the pedal box with the help of you and a few other Hoodies, im busy doing the inner panelling on the drivers side. Im hoping to get the diff, driveshafts and back end sorted over the holiday. Yes i got it powder coated. Cheers Cozzy.
  10. Cozzy
    Bolts
    Hi Andrew. Thanks for that. I'v been a bit puzzled by it, as i am a number of things! I didn't realise that about the loud pedal. Durrrr! Seriously though, it just isn't clear on the cd. Yes thankyou, i would appreciate the pukka bolt. Don't mind paying for it plus any postage/packing etc. Alternatively, i live 5 mins away from sth Normanton. Thanks for that mate! Cheers Roy.
  11. Cozzy
    Bolts
    Hi Phil. Thanks for the advice. Great blog! I'll be keeping an eye on it! Your Diagram and the photo's make it clear. (unlike the GBS cd i got with the kit) Still dont have an M10 X 160 bolt though! The only one in my bag o bolts is 200mm long. Thanks again, Roy.
  12. Cozzy
    Bolts
    Hi Matt. Cozzy, new member, not far from you! No it aint you mate. Im equally bewildered! Have you sorted your pedal box set up yet? Pressed in all the bushes, pushed in the spacer tube, which appears too long, and then the only bolt in the kit thats anywhere near the length i want, isn't long enough to get the loud pedal on! Also, what master cylinder are you using? Ciao for now, Roy.
