stug1985-2005
    21
0 Neutral
5 Followers
About stug1985-2005
  • Rank
    Builder
    zero kit car
    mark mcalister
  1. stug1985-2005
    Sierra Stalks
    that's it guys all done. had bit ov problem with my fog light wiring. cos I wired it for a live feed it was bringing a bad earth throu my lights. but changed it and my lights work perfect. thanx to all your help
  2. stug1985-2005
    Sierra Stalks
    brill guys il try this sat. if all goes well my wiring is complete . just need to tidy it up. il keep u update with the results
  3. stug1985-2005
    Sierra Stalks
    done more continuity testing on it nd 56 link to 56b when dip beam switch is on does ground. then when main is switched it switches ground to 56a. so will need to supply 12v to relay rather than earth. then my switch will earth the realy making it live. true?
  4. stug1985-2005
    Sierra Stalks
    sorry kept pressing post when I was typing it on my phone.
  5. stug1985-2005
    Sierra Stalks
    bg 11k665. da pin numbers. 53b. 53a. 53c 54. 30. 58 53. w. 53-2 31b1. 31b2. 56 the link was between 56 and 56 on the plugs. my engine is a 1982 but maby my stalks arent. there is an earth on the throu the hole that connects throu colomn. and a male spade on the top above pin 31b2. thanx.
  6. stug1985-2005
    Sierra Stalks
  7. stug1985-2005
    Sierra Stalks
    rite I decided to go to ma car before saterday so you's guys can no wot am dealing with. main relay. dip relay. pin 86- to column pin 86-to column pin 85-earth. pin 85-earth pin 30- to lights. pin 30-to lights pin 87- to 12v fuse. pin 87-to 12v fuse left stalk. ford 87bg13b 302 AA ( 30924 is on other side of 9119 20. relay) g48190 ( this is printed on back ov hazard relay) pin numbers. blank. ( no pins in place) 31. 54. L 56a. R. 49a 56b H30. blank 56. blank. blank 49. right hand stalk. ford vo 32031 87. bg
  8. stug1985-2005
    Sierra Stalks
    thanx mate. il be back at my car on sat. so il try a few things wot u said and if no luck il take a picture ov both the stock pins so u can c the numbers nd c wot u think.
  9. stug1985-2005
    Sierra Stalks
    soz the diagram coppied wrong. the first colors are ford loom nd second is Gbs. the colors all match up
  10. stug1985-2005
    Sierra Stalks
    switch pin ford gbs purpose headlights 15 brown white (thin) ignition headlights 56 brown black brown black link headlights 56a brown yellow white orange main beam headlights 56b brown white orange black dip beam indicators 30 red brown (thin) constant feed indicators 49 black red green flasher relay feed indicators 54 black white (thin) ignition indicators 49a black white green yellow feed to flasher unit indicators L black white green red left indicators indicators R black green black green right indicators lights 30 red brown (thin) constant feed lights 31 brown white (thin) lights 55 empty lights 56 brown black brown black link add wire to fog light switch lights 58 grey red side lights wipers 53 green yellow blue slow speed wipers 54 black violet white (thin) ignition wipers 53-2 black green wipers 53a black violet wipers 53B red grey red fast speed wipers 53c black orange washers wipers B1 brown white wipers B2 brown yellow wipers W black yellow ignition switch black yellow white (thick) ignition ignition switch red brown (thick) main feed ignition switch black blue white red starter ignition switch yellow accessory red white horn black earth grey fuel sender yellow black brake warning I got this from Gbs. everything works brill apart from main and dip. I havent got the pin 15 nd the link between the two stalks is 56 and 56, havnt got s 54? I get continuity on w, 53c and 53-2 to pin 56 when dip switch is on. so I tried giving them feed nd just blew the ignition fuse. so to rule out the relay wiring I put the dip an then the main beam on a pin that got a love feed nd switched on no bother. il try earth 31, jst it says that it's a 12v feed?
  11. stug1985-2005
    Sierra Stalks
    I had a good look at my stalks. I haven't got a pin 15 just a pin 31 in it's place. but doesn't give 12 v to lights. the flash takes a difo feed and is working, so is sidelights. jst trying to figure out wot pin gives the headlights a feed. they are 1982 stalks so are old ones.
  12. stug1985-2005
    Gearbox Leak
    cool thanx. il give it a go nd c.
  13. stug1985-2005
    Gearbox Leak
    hi guys, am getting a gearbox leak from where the gearbox meets the bellhousing. only noticed it when I finally got the engine running. I looked up the haynes manual and I didn't realize at the time that I need a gasket between the box and bellhousing. do u think I can temp put seal round the edge to get it throu Iva? cos if not I will have to take the hole engine out. its a pinto engine btw. thanx
  14. stug1985-2005
    Sierra Stalks
    got my multimeater out. getting ground on pin 56 and pin 56b when dip beam is switched. tried both ov them but still nuthin. getting ground on pin 56a when main beam is switched and flashed. but only works on flash? I tried both the w/o main beam and o/b dip beam that goes to relay on the wiper switch to c if it does work when switched nd both work when I switch that?
  15. stug1985-2005
    Sierra Stalks
    I've earthed the female spade on right hand stalk and earthed where the fixing screw is on right stalk. thick cable I've used. is that all I have to earth? is everything earthed throu the switch?
