2,235 -
49
Posts posted by MarkBzero
Gravity normally gets me in the fun starts when I try to get out.....
Like some of the other guys I am working to a budget and don't care if it takes 2-3 years to complete with workload and family commitments. Time consuming part so far fitting the old sierra loom, had to cut a lot out and extend some wires not difficult but takes alot of time.
But its all worth it as you see the car coming together.
Dan,
You will have a distinct advantage of knowing the history of the parts and I imagine most will be a simple transplant. Also if you are happy with your lights I'm sure GBS will deduct them from the package (they did this for me).
Sounds like a good plan and consideration for the next project.
Mark
Jez,
I have finished with mine you are welcome to borrow it I will not need it for a while.
Regards
Mark
Really good worth a few quid just for the story, nice car as well.
Mark
Cheers Kev.
Greavesy please let me know payment details.
Thank you
Mark
If Kev does not want the pods I'll have them please.
Regards
Mark
Thank you, I hope the welded brackets GBS put on the chassis are in the right place.
Mark
I can't deny it black and white does look very smart, but you nearly had black, white and lemonade. My son was very close when his bottle exploded on the floor very near the carpet. But then he's either hoodie in the making or needs an asbo!
Any chance we can have a close up photo of mounting points, a picture speaks a thousand words please. No rush I am going to fit the rear arches next weekend.
Mark
Looks good, although the whole Rhocar area was good compared to others and generally you let people get up close to the cars. I wonder what colour is the most popular, I'll have to ask GBS next time I visit?
Mark
Good progress can't wait to see it in the flesh.
Mark
Welcome minibigfinch (what's the story behind that name?)
I agree with Kev keep it simple get the car built then consider the many enhancements to improve performance.
Any questions just ask someone will answer or pop around to help, once you become a full member you can loan specialist tools/equipment.
Best of luck.
Regards
Mark
Stuart,
I was going for twin webers but most people generaly agreed with you so suggested that dellortos DHLA were better and more reliable. Trying to keep cost down and the donor car had a xflow fitted (south Afirican Import) the exisiting manifold and carb will not fit without moving a chassis rail and cutting a hole in the bonnet. This enginge/donor choice is causing more then one problem whilst building the zero but hey that's half the fun. Not looking for a speed demon just an enjoyable build the new xflow manifold has a slight upward angle which clears the chassis.
Regards
Mark
Hi All,
I am going to fit twin Dellortos DHLA 40's I have got a set from ebay but needs a few spares. What I am after is any information about choke size, main jets, idle jets etc when fitted to a xflow, any further advice and a picture of setup (either xflow or pinto) showing throttle linkage and fuel runs would be appreciated. I know it will have to go on a rolling road eventually but is there a basic set up process to get the engine running?
Rgards
Mark
Dan,
Looks good very similar to the lights I'm fitting, but I decided to go for a reverse light and fog.
Mark
Definately the way ahead to keep her indoors happy.
You don't need a V5 to build or register but you will end up with a Q plate.
Regards
Mark
I agree did not stay over but thanks to the guys for a brew and some advice.
The way I see it working makes money and pays the bills can't be help! Think of retirement and the joys of driving in the future.
Thanks Nigel, Good find.
Perfect going to order one better then playing around with a pinch bolt at the pdeal end.
Regards
Mark
Chris is right I had one on my high spec sierra (African import) loom you will not use it so cut it off. It included a bulb failure device, low brake pads, low coolant and low washer lights etc. If I remember I had to re-join an earth cable and one other so please remove one wire at a time.
Regards
Mark
Best of luck hopefully first time pass.
Paul,
Thank you, appreciated.
Regards
Mark
Stainless Steel 5 Slot Louvered Boat Vent
in Fitting & bodywork
Duncan,
Dpends how you are going to fit them if mounted from under the bonnet I would suggest countersunk stainless rivets that can be filled and repainted to match the bonnet. If fitted externally I would go for normal staianless steel rivets to match the louvers, again personal choice.
Regards
Mark
