JimmyRH
About JimmyRH
  • Birthday 04/17/1983
    Serie 3
    Jimmy de Tree
    Netherlands
  • Interests
    Kitcars
    Watches
3,027 profile views
JimmyRH's Achievements
Getting there Builder
Getting there Builder (3/5)
8
  1. It's all back out... and the bar is back in. Maybe in the future when I have more time I will start again.
  2. Checked the room and sizes again and again, but I'm not going to do it.. Nobody in the Netherlands has done this, and I'm just afraid I will drill the wrong place. I keep ending up near the engine mounts, and there is less then 1 cm room between the side and the mount. No option to mount something. I will mount the Sierra bar back in place and get it lined up again.
  3. Thanks, wil check this weekend the exact location.. Can twist a bit and shorten the tiebar if needed.
  4. Can anybody give me some more measurements please? installing the Tiebar conversion as winterjob now. I got the tie bar designed as on the image from Richard, got the Sierra bar out to see how and where they will fit but I am not sure where to mount the bracket on the car. I can only drill holes ones in the body . What Are the angles and or inches for mounting them on the right place. When I fit them as they are now they come at 35 cm (14 inches) from the support arm mounting. But this is at the same place the engine mounts are in.. so no space for a bracket / L plate on the inside.
  5. Thanks @brumster, really good advice! Will start over, and tweak it bit by bit. I have a well known road to test it.
  6. Hi, Yes GAZ coils have clicks, 20 in total.. So I started on 10.. but, not sure what is soft (more damping) and hard (stiffness) so
  7. OK, so 1.5 full circle from -.. but is - soft, or hard? Can not really ind the correct info. Also need to remove the Sierra antirollbar to fit the tie bars.
  8. Got them all fitted up in te car, the front was terrible to reach, even had to disconnect the radiator and coil to get the bolts out but they are in. In the front I have them a bit lower then before, the rear is the same height. But now, I am struggling with the set up.. on the screw is a - and a + I have started in the middle and have been testing with +2 towards the +.. and been doing this for a few times now but I can not seem to get it correct. I believe I have it to hard, on asfalt, no problem.. but on a brick road, my teeth are coming out and my kidneys have dents in them.. Not really sure how to set them and is - or + softer?? kinda lost. I think specially the rear is the working area.
  9. And they have arrived I have fitted the rear ones yesterday, the front ones I will start on today, this is a bit more work with the stainless steel bar in front. Will let you all know the outcome.!
  10. Great to hear that I have the right sizing.. Can't wait to receive them.
  11. Thanks for the image en info. I have just ordered a custom set of GAZ GP Range @ Dave from Dampertech. 14"open, 10"closed.. Mine has a different top mounting box at the top. Otherwise 16"would have been perfect. I ordered 200LBS springs with them.
  12. Dave from Dampertech is sorting stuff out for me regarding the shocks. Now about the spirng rate for the rear, would 125 also be enough? I took the old out of the rear, and this one is very dead. 14"open 10" closed with a pen mounting on top.
  13. Thanks for the info. Dave from Dampertech Should be back from hi sholiday after the weekend so I will ask him if he has any options for the rear.. The front ones I will take: Coilovers 13" open, 9" closed 1,9" ID diameter with 125 LB springs. Is Gold racing worth the extra pay? or will the regulars work also just fine? Or will this also be fine for my road use? GAZ Universal Coilover 1.9" 13” Open 9”
  14. Do you have some images of the rear shocks/mounting points?
  15. Thanks, where they the same size as the old ones in front? or is ride height changed? they are 125 lb.
