Stewart
Everything posted by Stewart
  1. Stewart
    clutch
    Looking for someone who has or can change a cable clutch to an hydraulic clutch with a servo on a Mk 1 Zero with a 2Ltr engine and a type 9 gearbox.
  2. Hi all has anyone changed a type nine manual gearbox for an automatic on a 2010 zero with 2ltr pinto engine
  3. Can someone please measure the distance between the rear bulkhead and the top of the roll at behind the seats.I have a shower cover that does not fit we’ll wondered if it was because I have cobra anti roll bars.Stewart
  4. Stewart
    spark plugs
    whats the best recomended spark plug for a non modified 2ltr pinto
  5. What do you guys out there consider to be the best smart charger that can be left all winter to maintain a battery
  6. Stewart
    Wrapping
    jasonj1970 has carbon wrapped his zero himself and made a crackin job of it,try contacting him I am certain he would give some advice
  7. A neighbour has given me some diodes he says are suitable they have markings of SKE 1/12.I cannot find the suggested maplins ones on their website
  8. I know side lights do not go through a relay, the feed I picked up to put the side lights on permanently I picked up from the relay
  9. I have LED lights around the front grill this is fed from the relay for the radiator fan,just fitted the new GBS head lights with led side lights.I initially wired the new side lights to come on with the front led`s and then thought this would be illegal as side lights are obligatory lights and should work without the ignition on I then wired it with the sidelight switch as well but this caused feedback and when the sidelights were switched on the ignition came on.how do I stop the power feedback to the ignition
  10. My son-in-law has a aluminium land rover and he allways uses the old fashioned brasso
  11. If I change the rear indicators to led and leave the front with bulbs will an led flasher unit still work all lights correctly or should I just fit resistors.
  12. Surely that is why the original idea was for a rotating area venue
  13. I have the choice of two area meetings both about the same distance away a round trip of aprox eighty miles,not I have an hour to spare or a last minute pop out trip especially when you do not have any wet weather gear.Perhaps if members went to a meeting on their doorstep and liked it they would be more inclined to attend meetings further afield.
  14. Why doesn't the monthly meeting move around the area giving all members a chance to attend a meeting fairly close to them
  15. Stewart
    Bump Steering
    Wanted was for the solution not the problem
  16. Stewart
    Bump Steering
    thanks for the info but must say in seventy years its the first time I have ever been called that seriously or otherwise
  17. Stewart
    Bump Steering
    I was told this morning by a racecar mechanic that because my lower suspension arm and my steering arm were not parallel this could cause bump steer and rose joints were the way to adjust them.
  18. Stewart
    Bump Steering
    Does anybody know where I can get a rose joint kit for sierra steering rods
  19. Stewart
    3 Years Work
    looks the dogs b------ks
  20. Stewart
    Pinto Cooling System
    I used the heater outlet pipe put a drain tap in it and used it to expel air from the system
  21. Stewart
    Red Grill
    Red powder coating would look good
  22. Stewart
    Brake Lights
    should one not say cream crackered
  23. Stewart
    Brake Lights
    power to the switch short switch out lights come on,
