harvs
Everything posted by harvs
  1. Mine did the same. The u-clamp holding the rack in place was flexing trough the mounting holes and it was the threads which created the clunk when they slipped. I think I added some packing (plastic pipe) around the rack to keep everything tight - was a long time ago though, so can't remember exactly!
  2. harvs
    New Toy
    Have to change your signature now...
  3. harvs
    Smallways 2013
    Please add me on to the list Lee Cheers James
  4. harvs
    Superspec Fuel Prime
    If it's the fuel tank as supplied in the superspec kit, then there is a swirl pot inside the tank. I've got the same large fuel filter - but it sits in the horizontal position. Which direction does the fuel flow from the bottom of the filter - to the engine or back to the tank?
  5. harvs
    At the risk of telling you how to start an engine (don't want to appear patronising!).... do you give it a bit of throttle when you turn the ignition? With no throttle mine takes a few goes from cold. But with a little throttle, it starts first time every time. (Touch wood....)
  6. Yep. From what other superspec users have reported, the one supplied with the kit was not really compatible. It was marginal whether it would pass the emissions, and with the engine / exhaust / sensor ageing there's little chance of it getting through. So, with a proper sensor, any easy fix.
  7. Phew, it's passed! I fitted a NGK NTK OZA527-E9 sensor and it flew through the emissions test. I had trouble getting the old sensor off though. To get through the test initially, the advise was to make sure there were absolutely no leaks in the exhaust system. So I used exhaust paste on the lambda threads, which meant it was pretty much welded in place. I broke a spanner trying to get it off. In the end I cut the lamda with an angle grinder and then hammed a socket onto what was left of the nut and used a breaker bar. Anyway, I'm pleased to be back on the road. Hopefully get a few more runs in before winter sets in. Cheers James
  8. Thanks guys I've done a bit more searching on this site, and it definitely looks like there was an issue with the lambda units supplied with the kit. I'm about to order an NTK unit which is for use with the Rover engine. I'll keep you posted
  9. Just failed my MOT on the emissions test: Fast Idle Test CO 1.6% (should be less than 0.3%) HC 55ppm (OK as as less than 200ppm) Lambda 0.944 (should be 0.970-1.030) Natural Idle Test CO 1.3% (should be less than 0.5%) I was expecting to pass the emissions as it passed OK at the IVA test 3 years ago, and I haven't changed anything since then. I know lots of superspec owners have had issues with emissions and there are a whole range of reasons/solutions which have been necessary to get it sorted. I think I'll start with replacing the Lambda sensor, and see where I get with that. Cheers James
  10. Mine passed the IVA in 2009 with 'current regs' for the emissions - so shouldn't need to prove the engine date.
  11. Sorry to hear your news Steve. Hope you get better soon. James
  12. Thanks Jon / Al I've ordered the gasket and found a breather for £3 . Just need to practice my welding now! Al - Great news on your progress. Look forward to hearing more in due course.
  13. Thanks guys I chatted to Steve (redspec) a while ago about fuel tanks for the super spec which got me thinking. I'm planning to do what you look to have done mr zed. Cut around the fuel pump/sender from the Ford tank as well as taking the plastic swirl pot. Then fit these into a fabricated tank. I'm going to have a go at making one out of mild steel. I know this isn't the perfect material, but plenty of the locost 7 builds take this route successfully. Will give me some good welding practice with my welder! Al - how's your car coming on? Thanks for the gasket offer but think I'll probably need quite a reasonable size. Done a little more searching and seen this on ebay which looks like it should do the job. Your tank does look nice. On the breather topic, my latest thinking is to maybe just use some tubing which is sufficiently high enough not to drain the tank contents. If it was a track car then could justify the £30 for a proper valve. But I'm really not planning on turning the car over...
  14. Cheers Andy. That sounds exactly like what I need. Although the price is a bit seep!
  15. Hi I'm going to have a go at building a fuel tank and have a couple of queries someone may be able to help with.... 1. Breather. What's the best way to install one? I want to avoid the tank self syphoning! 2. Cork gasket. I'm thinking of using cork when fitting the pump/fuel unit (will insert into tank from the top). Will any cork do or does it have to be fuel resistant (not sure if cork is naturally fuel resistant!)? I've seen some here which says its "Nitrile/Neoprene Bonded Cork material suitable for use with oil and water applications" - would this be ok? Thanks for any help James
  16. Have you tried checking the fuel pump relay?
  17. Think mine was about the size of a 10p piece No wonder it only lasted a few miles!
  18. Hi Ian On the superspec the gearbox mounting/chassis is very close to the speedo output so a gentle curve is nearly impossible!
  19. Hi Pete Just read your post and was wondering why you needed a new cable? My superspec broke the speedo cable on the first run - cable broke at the tight radius near the gearbox. My solution was to fit an angle drive (from Speedograph). It cost a lot more than I wanted to pay, but has fixed the problem. If you're getting quite a lot of miles out of each cable, then probably not necessary for an angle drive, but may be something to bear in mind if you have any future problems. Cheers James
  20. Yep - I'll hopefully be there. Wanted to go last year but it clashed with something else.
  21. Cheers Andy I've had the injector out and tired 12v to it directly - it's kaput. Swapped it with another injector just to double check. So, hopefully with a new injector I should be up and running again. For future reference if anyone else has a similar (rover) problem, the guys on the rover tech forum are really helpful. Thanks for your help James
