IJW
    80
0 Neutral
1 Follower
About IJW
  • Rank
    Getting there Builder
  • Birthday 01/12/1968
    nuneaton
    2b/04
    ian walker
  1. IJW
    Bonnet / Scuttle Alignment
    i put some of this trim around bonnet edge it then seals on scuttle when shut and takes out imperfections. http://www.cbsonline.co.uk/boot--door-seal...-trmbl-48-p.asp Ian
  2. IJW
    Pair Of Trs Belts
    Have you got a link to these Ian
  3. IJW
    Carbon Fibre Dashboard
    I got one from svc but took it back as it was to small even though the site said it would fit a robin hood .Did ask gbs if they planned to do any they told me they had the vac forming kit etc and planned to do them that was earlier in the year might be worth a call.
  4. IJW
    Gbs/bogg Manifold Prices
    I sent my zx6r carbs up to bogg brother it came in at about £300 i think, that was to have them cleaned, jetted to suit engine,5mm tapped hole on each leg for megajolt map pressure,fuel resistant rubbers and clips and centre water take off inc return del i only paid £!.54 for carbs off ebay. Ian
  5. IJW
    Indicator Repeaters For Iva
    Thanks for pointing that one out john hadn,t measured that thinking cap back on i think it might be an extender where headlamp is bolted over top of front mudguard and stuck onto that it says on that iva manual by standing rearwards not behind the car suppose it can be read many different ways. Ian
  6. IJW
    If putting the repeaters on the moving mudguard may cause a problem i think i might stick one either side of the anti roll bar.
  7. IJW
    Bubble Screen
    This is link to the seller non listed at mo http://cgi.ebay.co.uk/TRANSIT-ARCHES-Tidy-...id=p3911.c0.m14 Ian
  8. IJW
    Electronic Speedo
    I used these 2 part numbers REVFSS REVT9-A from here https://www.burtonpower.com/product_main.as...speedo%20sender The REVT9-A fits where your cable goes in the gear box and is secured with the circlip as you would the cable then the ford sender REVFSS screws onto that. Ian
  9. IJW
    Electronic Speedo
    I have fitted a ford sender unit into my type 9 gearbox and using etb guages works fine. Ian
  10. IJW
    Iva And Rear Fog Lights
    If you have a look here there is a couple of diagrams http://community.rhocar.org/index.php?show...6&hl=stalks
  11. IJW
    On the sierra stalks i have just wired mine in on the stalks that turn on the head lights on there is a -ve wire looping over to the dip/main that creates a circuit when switched on (but no circuit with just side lights on) i have put a live to the fog and branched into this -ve wire to a fog light switch then to the fog light so the switching is created by the -ve signal may put a relay in yet in case the sierra switch cant cope with the amps. Ian
  12. IJW
    Vro Chassis Number
    I wrote to the dvla in birmingham requesting a chassis number and here is my letter of reply Thank you for your letter regarding the allocation of a vro chassis numberfor you amateur/kit built vehicle. In order for me to allocate a vro chasis number i would first need to receive the application forms and paperwork necessary to register the vehicle.Once i had checked the paper work i would need then to inspect the vehicle to ascertain that there was a need for a vro chassis number to be allocated.I would then allocate the vro chassis number and issue a v842 letterto enable you to have the number stamped into the chassis .The vehicle could then be taken for IVA.Once the IVA certificate had been issued and forwarded to me i would then be able to complete the registration process. The police have expressed concerns about the amount of vro chassis numbers that are being issued for amateur/kit built vehicles.Where possible they would prefer the use of vro chassis numbers for vehicles of unknown origin and identity only. With this in mind the instructions that i have are that you are able to create your own chassis number and have it stamped onto the chassis.The number must be between 9 and 17 characters long and should be made up using a mix of letters and numbers.Due to a computer system constraits you cannot use the letters Q,O or I VCS INSPECTIONS BIRMINGHAM LO So in that i read i can just go ahead and make up my own chassis number without the need to fill out any forms or have an inspection until i have done IVA. Ian
  13. IJW
    Superspec Dashboard
    I brought one of the dashboards from svc but took it back it was to small for my 2b4 by about 2 inches at the sides so ended up using mdf. For the speedo i fitted a ford sensor in the speedo cable hole using an adaptor from burton power this worked fine with the etb speedo . i got a new level sensor from etb to suit guage. Hope that all helps a bit Ian
  14. IJW
    2b Aeroscreen
    Thats the one i fitted pic here http://community.rhocar.org/index.php?showtopic=23705 Ian
  15. IJW
    Iva Mirrors
    I have less vibration on the mirrors now i have done this than i had when they were directly on the scuttle i thought i would have got more vibration.
