2,667 -
42
Posts posted by steve in stockport
Kev
just been on the locost site and came across this thread for wheel bearings at halfrauds
£10 a side seems ok to me
cheers
Steve
peugeot 205 fan switch is 22mm thread as Jim said, fan comes on at 88 deg and knocks off at 79 deg, vauxhalls opens at 99 and knocks off at 95.
or go to your local spares shop and check the catalogues for the switch that gives the temp range and fitting you want
Steve
had a similar light come on just as the engine died for the first of eight times whilst on holiday in france. don't know about vauxhall but on nissan it is an engine management malfuction indicator - turned out we had a broken crank position sensor and the management kept resetting itself only to pack up again later on, it was like russian roulette tpwing a caravan along dual carriageways knowing it could pack up at any time with dirty great big french artics all around!!
the sender nearest the front of the block (fan end) is the water temp sender for the dash, the one towards the rear of the block is the oil pressure sender.
the inlet manifold has another sender for the ecu which helps it decide how much fuel to let you have etc.
Steve
try contacting a local engine builders/reconner to see if they have any sumps kicking around. the one local to me said to bring my original sump and compare it to the ones he'd kept off dead engines - who knows might find a capri 1600 one, i think that one fits and gives extra ground clearance but i stand ready to be corrected
cheers
Steve
she'd never bang her nose if she fell over!
volkswagon type 2's (campervans, pickups, vans etc) had a dash mounted pull and twist handbrake that looked very similar to that, but a bit bigger.
it was attached to a long lever that went out through the floor to a pivot point then it operated as a normal handbrake does.
could be possible to adapt if you can get the bits off a dead v dub van
cheers
Steve
Gutted, the bloke went and sold the seats before I got back to him - not surprised at £30.
The moral of the story is he who hesitates is lost!
Thanks for all the info will have to keep a look out for more from the rave reviews you all gave them
cheers
Steve
I've come across some mk 1 mr2 seats for sale at £30 the pair, black cloth with grey centres, all the runners and none of the usual wear you see on so many seats for sale. I know they won't be waterproof but management is pulling her face at £400 for a pair of cobras so these could be good as a starter while i skim some cash off the housekeeping!
Just got a few questions:
has anybody fitted these to a 2b?
if yes did you have any problems?
are they a bum friendly seat or will someone have to give my backside the kiss of life after each trip?
cheers
Steve
just want to say the vauxhall injection micro filter between the pump and the injectors is about a third of the size of the coffee tin sized rascal from the sierra.
it has 8mm tails in and out and makes fitting a bit easier when things are getting a bit tight in the engine bay
the ford pump is gravity fed and needs to be as low as possible, ie below the bottom of the tank but a vauxhall injection pump will suck/lift the fuel up to 15 inches/400mm or so.
any more than that and you will sieze the pump cos the fuel cools and lubes the pump as it passes through it
Derek,
first off have you tried one of the fuel pumps just connected to a battery - off the car of course, without fuel for a few seconds.
If it runs connected like this then your problem will be either in the wiring, maybe a bad earth or with the box of tricks that runs the efi.
If it doesn't run just on the battery then you may have been unlucky and had two bad pumps.
hope this helps
Steve
The AA recommend a spare set of bulbs if your driving in France but if French plod pull you for having a light out they expect you to fix it there and then - if you can't they are more than happy to relieve you of some of your French beer tokens with an on the spot fine, but hey what do you expect from people that eat snails!
Going over there in june towing a caravan - now that has some good rules - spare bulbs for car and van, gold tow ball and something to do with tyre ratings among others.
what a feeling - I had my maiden voyage last week, 20 feet up the drive then a full afternoon of fettle, tweek, polish, rub then 20 feet in reverse back into the garage.
had a stupid grin on my face all the time and loads of comments from neighbours and passers by.
the robin hood exhaust noise works a treat for waking up hung over student layabouts - next doors lad was not pleased - tee hee!!!
yes, if you're not running a heater the pipe from the manifold will go back to the water pump.
once it returns there it mixes with the remainder (majority) of the coolant to be pumped through the rad then back into the bottom of the engine.
so if your pump works there is a continuous process where cool coolant enters the engine through the bottom hose, passes through the waterways in the block, head, manifold etc picking up heat as it goes.
the heated coolant then passes through the pump to the radiator where it is cooled as it drops to the bottom hose, then it all begins again
the water is pumped out of the bottom of the rad, through the engine then out of both the top hose to the rad and the inlet manifold, through the heater and back to the top of the water pump.
sounds like you have very little circulation, so if your stat is new, tested and in the right way around the thing that gives you circulation - the pump -is the next place to look
steve
sounds like your thermostat is either duff or fitted the wrong way round.
as the pinto warms up the water is circulated round the pump, head, inlet manifold and heater( if fitted) til the water is hot enough to open the stat, it then goes round the whole system.
just a little heat on the rad side looks like water struggling to get through the stat for one of the above reasons.
steve
I've fitted a seat marbella rad on a wishbone 2b, sits upright at the front of the chassis.
not on the road yet so not been used in anger but seems to cope ok.
haven't fitted a heater so the system only has 10 pints of water in it and stood running on the drive for 30 mins in the hot manchester sun (23 degrees!) on monday with no ill effects.
I'm going to change the fan switch for a cooler one as the vauxhall one i used operates at 100 degrees- still well inside the norm range on a sierra dash.
either follow big jim's link to the rads page on the nw hoodie site, it's at the bottom of the page or pm or mail me for more info and all the photos.
steve
flea
you haven't said what pressure rad cap you are using, early sierra caps operate between 12 and 16lb (13lb cap?) and later ones at 15 to 18lb (15lb cap?).
apparently for every one pound increase in cap pressure you raise the boiling point of the coolant by 3 degrees - so maybe a higher pressure cap might help.
some motorsport teams use 21lb caps so they can thrash their motors without them boiling but that might just hide a problem til it causes serious damage to your engine and your wallet!
do you know the temp range of the switch for your fan?
pop down to your local spares shop and check the ranges in the books for switches with the same fittings as yours - these can vary by as much as 20 degrees so you can choose when your fan cuts in
steve
hi cwing
the best place i found for p-clips is maplins the electronics shop - they have shops all over the place or you can buy online.
white nylon/plastic clips start at about £1.00 per 100 for the smallest size.
or pm me with your address and will send you some - i've got about 50 left for brake lines and 8mm copper fuel pipes
steve
i'm experimenting with a seat marbella radiator at the moment, fits vertical right at the front of the chassis on a wishbone 2b,it's a two core aluminium job, the connections are the same size as the sierra and in roughly the right places.
got it fastened to a nissan micra expansion bottle and i'm tryin to find a front mounted fan to blow through it.
this set up will give me shed loads of room between the rear of the rad and the engine for other odds and sods - will keep you posted with how I get on.
steve
peril
it might not be bad news all the way - you say that you've just finished running in but you don't say if you re-torqued the head bolts after the engine was run up to operating temp for the very first time after the rebuild.
suggest you whip the head off, put back on with new gasket and bolts run it up to temp then while it's still hot take the cam cover off and re-torque the head bolts - they expand when the engine is hot!
once it's cooled you have to reset the tappets(cam followers) then refit the cam cover - thats what mr haynes says to do.
good luck steve
Seats
in Chit chat
i hope these will fit cos i just won them on ebay
link
if they do the red leather will look the business with the red grp on my car!
cheers
Steve
