turbo
    655
0 Neutral
6 Followers
About turbo
  • Rank
    Wheely good builder!
  • Birthday 09/24/1973
    2b plus ss 2004 2ldohc lowered inj.mt75 g.box mod.prop&brakes.lowered aluminium sump.
    jamie
Contact Methods
  • Website URL
    http://
    lanarkshire central scotland
  1. does the granada use the same driveshafts,diff brakes,front uprights steering column as the sierra? thanks jamie.
  2. yes still got them,these set me back £76 so would be nice to see a return on them.
  3. turbo
    Will I Fit?
    as its for track mate you will be best with the zero.
  4. http://community.rhocar.org/index.php?show...c=22545&hl= i offered these some time ago.
  5. get stuck in andrew b4 that baby comes then you can just sell it at a loss (congrats by the way)
  6. all twinkies i have seen have it as you say on nearside using holes on block.
  7. 200lb would be fine on most sevens with independent wishbones at the rear but on the 2b with the sierra set up you will need the 300's to stop it constantly bottoming out at the front mount bolt of the rear wishbone.
  8. vibration was my warning b4 it eventually let go at top speed on the 3rd lane of the m6 traveling home from stoneleigh. if i ever own another rh. the prop will be changed right away. when i got the new one from dunning & fairbank i then understood why the rh ones were known for failure.
  9. zero every time for me.its what the car should be.
  10. i would advise anyone with a spare £150 pounds to get a proper one made at dunning and fairbank,probably the best spent upgrade you will get and may even save a leg one of these days.
  11. sorry you have to sell up tony. sometimes other things are more important than toy cars. at least you have managed to do it young and can always return to kit cars again. keep me in touch where this well travelled car goes,all the best with the sale. jamie.
  12. turbo
    Electronic Speedo
    on the twin cam mt75 box the pulse wire at the ecu is either brown yellow or it was yellow brown. this worked for me to replace the magnets.
  13. turbo
    Which Flywheel?
    THE FLYWHEEL AND CLUTCH FROM A 1.8 ZETEC IS MUCH SMALLER,LIGHTER AND WILL FIT,ALL YOU NEED TO DO IS EXTEND THE THRUS BEARING BY ABOUT 20MM.
