Search the Community
Showing results for tags 'Design ideas needed'.
  • Search By Tags
  • Search By Author
  • Committee Matters
  • RHOCaR - Information and Events
    • News
    • Events
    • Club Information
  • Construction
    • Chassis
    • Donor
    • Fitting & bodywork
    • Engine
    • Mechanics
    • Electrics
    • IVA
  • Adverts
    • For sale
    • Wanted
    • Other classifieds
  • Members Lounge (Access is via RHOCaR membership only)
    • Member Discounts
    • Loan shark
    • Build Threads
    • Build Blog Links
  • On the road issues
    • Maintenance & Modifications
    • Driving
  • General
    • Kit car related
    • Chit chat
    • Test area
  • Moderators
Categories
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Website URL
Location
Interests
Car type
Full name
Found 1 result
  1. Thrashed
    Ramp
    Hi All Well after a lovely day yesterday, the rain has started to fall so the mind has fallen to jobs on the `to do list'. Background: I currently have a home made ramp for getting the kit to a height comfortable to work on and high enough to be able to get underneath. Currently the ramp is made out of 2 RSJ's (I beam) which are separate but tied together with 2 x 50mm (2 inch) scaffold poles. The end of the ramp currently sits at 700mm high which is a great height to work at and get underneath. https://photos.app.goo.gl/zQsE0mrrwtQ6xBrE2 The end and the straight is held together with 6mm plates. https://photos.app.goo.gl/9KEzPCEUbtB61ZVq2. I have mainly been using it as a ramp but would love to be able to use this as a platform. The big issue i have is getting the other end in the air. Currently i have a farm jack that i use to jack each side up a little at a time and the ends are then sitting on 2 x 50mm scaffold poles each side using trailer clamps which hold 750kg each. (https://photos.app.goo.gl/PCkmeFcsGbhyDkif1). This is very dodgy to say the least, it is not 100% stable when up and the whole process of getting up is difficult and getting it down is just dangerous, so i have not been using it as much as i had planned. This is what it looks like when the ramp is up. https://photos.app.goo.gl/h0NmXQZErmBN4cBE3 Design brief: So, the help i need is to make this safe and easy to lift. Also to be high enough to be able to get underneath. Design limitations: Tools to lift the ramp are a 2 ton trolley jack with a maximum lift of 370mm. Farm jack, but really do not like using this as it does not feel safe (mainly on lowering) Would prefer to use what i have left metal wise, which is a 2m length of the RSJ and a sheet of 6mm steel. So what would you do? Thanks in advance Steve
