Search the Community
Showing results for tags 'Kit or Sierra'.
  • Search By Tags
  • Search By Author
  • Committee Matters
  • RHOCaR - Information and Events
    • News
    • Events
    • Club Information
  • Construction
    • Chassis
    • Donor
    • Fitting & bodywork
    • Engine
    • Mechanics
    • Electrics
    • IVA
  • Adverts
    • For sale
    • Wanted
    • Other classifieds
  • Members Lounge (Access is via RHOCaR membership only)
    • Member Discounts
    • Loan shark
    • Build Threads
    • Build Blog Links
  • On the road issues
    • Maintenance & Modifications
    • Driving
  • General
    • Kit car related
    • Chit chat
    • Test area
  • Moderators
Categories
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Website URL
Location
Interests
Car type
Full name
Found 1 result
  1. I want to sell all at one go if possible so will not split yet. Pinto 2ltr efi engine & 5 speed gearbox 205 block complete with ignition coil ,oil filter ,fuel pressure reg,engine mounts and rubbers, LSD transmission,pinion and mounting bolts, rubber coupling, main drive shaft, O/S & N/S drive shafts & hub carriers, Disc brakes,drum brakes and backing plates, Master cylinder, Pedal box, inner steering coloum, steering rack Sub Frame + lots of other little bits ,nuts ,bolts brkts, leads etc etc NO Management system All from same motor, D reg Sierra, 78000 on clock ,no problem with engine or gearbox at that time,dry stored for 6 years,vehicle was scrapped, no paper work sold in good faith. £500
