Search the Community
Showing results for tags 'temp rpm'.
  • Search By Tags
  • Search By Author
  • Committee Matters
  • RHOCaR - Information and Events
    • News
    • Events
    • Club Information
  • Construction
    • Chassis
    • Donor
    • Fitting & bodywork
    • Engine
    • Mechanics
    • Electrics
    • IVA
  • Adverts
    • For sale
    • Wanted
    • Other classifieds
  • Members Lounge (Access is via RHOCaR membership only)
    • Member Discounts
    • Loan shark
    • Build Threads
    • Build Blog Links
  • On the road issues
    • Maintenance & Modifications
    • Driving
  • General
    • Kit car related
    • Chit chat
    • Test area
  • Moderators
Categories
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Website URL
Location
Interests
Car type
Full name
Found 1 result
  1. Looking for a bit of info on the old pinto ESCIV injection system, not sure if I have a prob or not. When starting cold what is the RPM, mine tends to be around 1500. What temperature does the cold running setting switch to warm, my revs drop to normal at around 90 degrees. 90 seems high for the cold setting to still be on, its the same temp the thermostat opens or its switching off due to thermostat opening.So could temp sensor be stuffed? Thanks
