Search the Community
Showing results for tags 'zetec conversion'.
  • Search By Tags
  • Search By Author
  • Committee Matters
  • RHOCaR - Information and Events
    • News
    • Events
    • Club Information
  • Construction
    • Chassis
    • Donor
    • Fitting & bodywork
    • Engine
    • Mechanics
    • Electrics
    • IVA
  • Adverts
    • For sale
    • Wanted
    • Other classifieds
  • Members Lounge (Access is via RHOCaR membership only)
    • Member Discounts
    • Loan shark
    • Build Threads
    • Build Blog Links
  • On the road issues
    • Maintenance & Modifications
    • Driving
  • General
    • Kit car related
    • Chit chat
    • Test area
  • Moderators
Categories
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Website URL
Location
Interests
Car type
Full name
Found 2 results
  1. Guest
    Engine Dilema
    I'm after some advice..... I have a 2B whcih is running a Ford Zetec SE 1600 (Sigma) engine on a Megasquirt MS2 Extra Engine Management System. It has some modified delorto carbs (they are cut in half) acting as ITB's (sort of). It runs ok, and has apparently around 144bhp. Being a Zetec SE, the exhaust exit is on the Off-Side of the car making sourcing a 4-2-1 Manifold to replace the puny 4-1 that is in place difficult, and likely needing a custom fabrication job. So here is the dilemma! Recently I picked up a Zetec S (1700 Puma Engine) for a small amount of money. Its the same bolt pattern, orientation and footprint, but has better internals than the SE, eg Steel crank and rods etc. The original plan was to strip this engine, put some hot cams in it, add some bike ITB's, get some head work done (flow/ported, lifters, springs), and then drop it in as a straight swap with a new beefy 4-2-1 exhaust. The target being around 200bhp. Should I go this route, I can expect to pay £550 for cams, maybe another 200-300 on head work + the cost of a custom exhaust (I already have the ITB's), so maybe 2K all in. However, along the way I picked up a set of GSXR ITB's on an ST170 manifold ready to bolt straight on an ST170 duratec engine (I also have a set of ZXR12 ITB's that are bigger but that would need a manifold, which I intend to design and 3dprint in Carbon reinforced Nylon). So the thing is, given the duratec ST170 engine is the opposite orientation to the S & SE but the same orientation as the Zetec E (Blacktop), eg, "Exhaust on Nearside", there are far more 4-2-1 manifolds available off the shelf (and hopefully second hand) mitigating a potentially expensive custom fab job. Also, being a 2litre engine, with the ITB's and ECU I already have, I am pretty sure 200bhp is achievable without touching the head or opening the engine. Add to that the fact that a decent s/h engine can be had for 300-400 and I could potentially hit the 200bhp target for about 1K, but that excludes any subsequent conversion work I have to do on the gearbox hookup, engine mounts and bodywork. I already plan to strip the car back to the chassis this winter, and therefore the engine is coming out regardless so while the S is an easier job, fitting something different is not a deal breaker. Thoughts, opinions, advice all welcome!
  2. Hi all, I have been steadily working on a newly acquired 2B Plus and so far since I brought it, I have installed a Zetec blacktop. The install went easily enough and I have re-wired the car and used the switch gear and fuse boxes from the mondeo. So everything works fine, lights, gauges, switches, even the timer on the intermittent wipers works however turn the key and no starter motor. I have tested the motor by bridging the battery positive and the motor terminal, and I have tested that the ignition wire has 12v to it so I am guessing it is the solenoid. It's a new starter but I suppose not uncommon. Is there anything that I am missing?
