Robin Hood
Guest Cpm 200
Guest Cpm 200
HI chaps I've just joined the club and not 100 percent on how it works. I've purchased a robin hood a few week ago went out in it the other day and it decided to pop the oil cap off I've been told it's something to do with the pressure but how could I sort it thanks
Sounds like you have a bit of crank case pressure. What's the spec on the engine, is it standard with all the breathers intact or has it been changed to twin webers or bike carbs and the breathers not reconnected?
You might just have to reinstate the breathers, or maybe take the middle from the pcv valve and pipe the outlet down and under the car or to a catch tank.
