Cycle Wings Fitting To Sliding Pillars
Guest essex
Guest essex
I have a 2b with sliding pillars - the fitting of the front cycle wing to the sustension strut has broke...
The plate that fits under the plate has cracked , and on inspecting the other it appears that the plate under the suspension springs on the other side is craking directly under the springs.
Is this a common problem?? does anyone have a solution? or is there supposed to be some added support that i am missing?
I bought the car built - so am a little nieve.
graham
Guest Mr Pid
Yes, i think that you will find this is a common problem on the earlier models, i think most people overcome this by welding some extra brackets to support them, and the later models were made more robust at factory.
I have this so i am going to keep a close eye on them.
HTH
Stu :rolleyes:
Hi.
Try ringing Richard at Robin Hood.
They have repair/re-enforcing kits for these brackets.
They even repaired one of mine for me and sent me the kit for the other side, all free of charge.
Piddy.
Graham,
I bought a pair of cycle wing brakets from RS Jigtech. They attach in a slightly different way than the standard RHE one and look alot more substantial. The are specially made for the 2B try giving them a ring.
RS Jigtec Ltd
Not sure if they still produce them, but they are the chaps to talk to. The also produced the wish bone converstion for the 2B.
HTH
Simon
Thanks for your advice everyone.....
It definately gives me a better lead to play with..
...hopefully be back on the road ASAP (when Richard gets back off holiday!)
Graham
