Dash
Guest chris.ridgers
Guest chris.ridgers
Im not happy with my dash fitment, there are larger areas in the corners that dont join up, to large for silcone i feel i tried everything to get them to line up. I found this carbon dash on SVC's website http://www.s-v-c.co.uk/prod_carbon.html (bottom of the page) just wondered if anyone had one and if so how did they fit it?
I got one someone had tried ( and failed ) to fit - think there was a height or width issue
I just used the centre console bit and the lower edge has the right circumference for SVA
Wouldn't have paid full price for what I wanted though
Fitting the RH parts is all part of the experience
The escort pod supplyed will fit if you make new bracket adapters.
Its meant to lay backwards to give a reasonable view angle.
If you do use the POD suggest you go to a scrappy and get the connectors.
The pod is from escorts with a Rev counter option and the two cost me 50p
Tony
Guest ballin
Blimey!!! Fair play to you, that must have been a hell of a job, looks fantastic !!
Was going to say though, bet sunny days are fun, mines bad enough with just the dash top being stainless
