john henry
Everything posted by john henry
  1. YEEEEHHHHHHH SOLVED, its the second photos my car exactly, a s7 cortina subframe kit, Many many thanks for your help Alan, Great help
  2. Aww, i recon you could be right??? thanks for your help DanDan62.
  3. HI i recently won a bid for this Robin Hood on ebay. I have no idea what kit it is? Its an early one for sure, reg doc says it was constructed in 1980 ?. It has a 2l pinto engine mated to a 4 speed capri box, to a live [ Escort ] back axle. It appears to use a cortina crossmember bolted to the body tub and is modified [ cut off ] at the front of the antiroll bar mounting points. This sticks out the body slightly at the front [ but has been hid with spotlights] Rather unsightly and questionable engineering, Iv only found two fairly heavy big bolts holding the subframe on so far, and a few wee 10mm bolts at the top mounting point, but typical Robin Hood engineering [ Iv built an Exmo back in the day]. Can any members shed some light on what kit it is?
