Search the Community
Showing results for tags 'tyre choice'.
Hi Guys So you know what it's like when you pick up someone else's half finished project... not everything is as it should be. I'm currently building up the front end of my 2B and to save some work bought the front wing supports from GBS to fit the original Array alloys with an ET15 offset. Now that I'm actually fitting the wheels the tyre rubs agains the wing support but only just. I suspect the tyre size is a little over ambitious at a 205/50 R15. What was originally intended for the 2B was it a 195/50 or 195 /45? A smaller tyre size seems the easiest solution and as
Hi All, I'm a new member - just bought a 3a (1.6 Pinto). Its the culmination of a long held dream to own a Robin Hood! All the tyres are old (newest was made in 1998). They're 185/60 R14s. I'd like to replace them all. Any advice as to tyre choice?
- 16 replies
- which tyre?
- tyre choice
(and 1 more)
Tagged with:
