July 26, 200322 yr Just got doner. What bits other than engine/gearbox/suspension, do i need to strip to start and what can i leave on car till later. I plan to put car on blocks (after removing engine/gearbox) out the back of the workshop while it will role. but have a ramp in the workshop, so anything underneath will be easer removed befour then.
July 26, 200322 yr just finished strip, after 28 june collection from my donor i've taken prety much everythin just to be safe and the task was surprisingly quick n simple. left with two boxes of bits + big oily lump the rear sub came out complete n with wheels n skate board is fully manouverable i'd been advised the loom i v imp (label as you go with white e tape n perm marker) esp engine section all the bits you dont think of are needed too like door rubbers, grommets n fasteners etc all thets on my drive is the shell with doors intact n not touched cut the front x members away to make e + g removal a doddle keep the wheels etc to scrub on the car when tracking etc setting later and also i'd been advised that for sva original wheels/ tyres calibrate better theres a good start article on build tipz on main site http://www.rhocar.org/buildtipz/037.shtml i spent some time goin through the haynes and looking for useful components like brake line t junction and decelleration valve some people have kept the wheel liners too but mine were brittle hope this is some help? r u building soon? have fun
July 26, 200322 yr Collected kit 28th of may, just got doner,have to put up concreat garage befour building starts, so hopefully soon!
