Cycle Wing Brackets
Guest DROID
Just trying to fit the cycle wing brackets, cut the multi bend tude as per the video, but when offered up to the mounting bracket attached to dummy strut found both tubes to be the same diameter? Even cutting a slot in one won't work. Any sugestions??
Andy :boohoo:
Guest TerryBarry
Hi Andy,
Did you not get a short (300mm) length of a slightly larger tube with the kit
There is an instruction to cut this into four equal lengths and use as a sleeve to connect the other bits.
Terry
No didn't get any additionall tube, is there an instruction in the video about this?? Off out to the garage to see what i can find.
Terry, again I appreciate your help.
Thanks Andy
Guest TerryBarry
Andy,
The instruction was on the additional information sheet we got on collection day(June '02).
Page 2 under "Latest Detachable Tag Type Cycle Wing Brackets".
All it says is " A length of tube is supplied Approx 12" long, cut this in four and use it to sleeve the tube instead of fitting one inside the other."
Terry
Guest paul mercer
i riveted mine, until i was happy with the fit, the welded, and filled the rivet holes with weld. I then ground away the weld into a smooth surface and it hardly notices as a joint of any type.
