Zetec
Guest gdc
have you tried a compression test will tell if valves shutting properly also 5w 30 is a must
That is normally the problem Craig the lifters fill and then the valves stay slightly open hence no compression
hi many thanks for all the replys
will try the 5w30 and see what happens.
also check the low voltage side of the coil pack.
regards graham
hi
had a little play again today and added a cleaner to the oil got it hot and drained it .
refilled with 5w30 and tried again.
there is a noise i would assiociate with a tappet clearance prob from the cylinder that ant working.
got the engine hot and it wouldnt clear. ]
will try again
#regareds graham
to my hero many thanks(nigel)
we changed the coil pack again no3 now and the missfire has gone, running sweet now.
it always makes me wonder how you can get 2 bad items in a row so you disregard the obvious and look at other things.
anyway new coilpack and sorted.
cheers for all the replies.
regards graham
Graham, the earlier zetecs can suffer from 'sticky valves'. I have done a lot of work on this problem. The valves stick in the valve guides causing misfiring. as has been said run on 5w30 only.
cheers simon
cheers for the input simon
but the third coil pack appears to have cured the problem.
my hero (nigel)diagnosed the prob some time ago but i refused to accept cos we had got to the second coil pack by then. fitted the third and prob gone.
runs a treat now!.
very responsive with the bike carbs.
hows the turbo going?
regards graham
