Zero Wiring Loom
Guest lucavigg
Guest lucavigg
Has anyone here received the wiring loom from GBS for their Zero, or did you take a loom out of a donor. I think GBS are having problems making them at the moment.
Luca
Guest David Walton
Luca
Yes Had a loom from GBS in the last 6 months. Its seems to be OK. Just fitted it to my Super Spec. Instructions lack details.
Not a bad made loom.
Almost wired up.
David Walton.
Been doing a zero and used the wiring that came with it.
I think GBS could have actually labelled the wiring.
It's not bad but I thought it was aimed toward a pinto engine due to some wiring having to be extended etc when I linked it to the zetec.
I would suggest you label it fully prior to putting it in the kit and test each part with a bulb.
I did have a few little problems with the relays, but a good 2hr thought session solved that.
I have slightly different setup though as I only wanted to use one stalk (indicator) so had to wire in light switches and hazzard switch
Ian
Guest lucavigg
Ian
I wish I had the problems you have had as I have been waiting for my loom for two months. Still, got a 1.8 Sierra to dismantle for the gearbox and bellhousing now, so that will be occupying my time for a while.
Luca
Guest mac801123
Luca
Hi Luca :hi:
I got a Zero with GBS loom, unlabled, the only problems I had was the relays and I made a link between 2 pins as instructed by them and fried my indicator stalk.
Pin 49 to 53C.
Hope you get on well Mike :good:
