Water Pump Gasket
NeilD
water pump on my 2.0 pinto started leaking over the winter.
treated it to a nice shinny new one...
first attempt ( no sealant just the gasket ) and it leaked at the top
second attempt ( found some blue hermatite lying around in the garage, gave the gasket a light coating each side and fitted ) all OK until it got up to temp and now has a small leak again at the top.
any suggestions for getting a good seal on attempt three :huh:
Guest peter2b2002
sounds like there is still a bit of the old gasket on the block, or a score where someone has used something to prise the pump off before. I have used the old red stuff before, also check that the bolts tighten fully and aren't bottoming out
peter2b
We always us instant gasket on all water pumps as well as the paper one just a light coating on both sides of the gasket.
Any particular brand - there seem to be lots around - thanks
replaced the bolt nearest the leak with a shorter one - so far its looking good :D
of course this was after a trip to the motor factor - more spare bits......
