Battery In Boot
Guest owenpilson
Guest owenpilson
Im thinking about moving my battery into my boot (bring on the flames)
my question is ,where can i get cable from @ a cheap price....
am i right in thinking that i only need to run a positive feed and strap the -ve to the chassis.
im going to stafford in a few weeks, would it be cheaper there?
cheers
owen.
  • 3 weeks later...
Guest kevin
Just a thought, what about using good quality jump leads with the gaiter grips cut off and crimping new ends on? You might be able to reuse the ends off your short battery cables.
Kevin Howard
Guest daveg
Owen
Make damn sure that the +ve won't come into contact with the chassis.....
i.e if the insulation breaks down for whatever reason (slight movement wearing through insulation) your car may catch fire :(
Dave
Guest Battery Bill
I think we have been here before :lol: :lol:
Give Owen some credit I think he had worked this out already.
Guest Battery Bill
Does this posting set me up for a barrage of abuse
No we are not going to mention tunnel panels fitted the wrong way round, :lol:
Anyway lets not start all this claptrap again. :rolleyes:
Lets just settle that if you want to put your battery in the back Good luck to you, and if you want to fit your Washer bottle in the back taking up valuable boot space good luck to you also. :p :p
Guest owenpilson
A big thanks goes to Bill & Joey for bringing me the cable on sunday.....
And im sure im not stupid enough to run a cable through the car without protecting it properly.
i will be running it through a piece of trunking , and ive purchased a battery cut off switch which i will mount in the boot also.
next week i will be mounting the following in the boot...
Radiator
Windscreen
nosecone
front o/s wheel.
and just so Ant doesnt feel left out ..... the washer bottle.
owen.
2 posts to his name and he jumps in this deep,  :lol:
Prey tell us Why ( Not the same old reasons ) something new perhaps  :rolleyes:
bill i would have more post but the site would not let me send them :o if you fit the battery in boot does it not take much needed space away not to mention the problems finding the correct rated wire ?
