Wiring
Guest carl leonard
Guest carl leonard
I recently purchased a set of dials from green gauges and need some advice on which wire goes where
Dials include:
Fuel
Temp
Volt Meter
Clock
Oil Pressure
The loom is from a G Plate 1989 Sierra.
1st Problem.
Can anyone give me precise details of where each wire (By Colour) should go and any connections that should be made between each dial (ie; linking up a single wire from the origional cluster to possibly two dials or more.
2nd Problem
I have been looking under the dash to try and find the socket that connects to the dimmer switch. I may have cut this away from the loom when I started trimming back??? Any simple ideas of how to trace the connection????????
Any advice would be appreciated
Carl.
