Wiring Diagram
Guest Wozzer
Guest Wozzer
Has anyone got a wiring diagram for the stalks of a 1990 boot model Sierra Sapphire?
I have found some examples on the site, but none of these actually say what the different wires are connected to.
I am trying to connect up my VG loom aaaaaaaaaagggggggggghhhhhhhhh. :boohoo:
Wozzer
Guest Stephen Robertson
Wozzer
You sound that you are at the same stage as myself
I connected the VG loom to the column switched as show on the plans , the colours did not always match those on the plans so i ignored the colours and connected the wires from the terminals to the VG loom as they came out of the back of the switches.
Hope that helps
I have had a look at the wiring for the instument cluster and an not loking forward to that ,and as for the ignition AGHHHHHH.
Cheers Stephen
Guest Wozzer
Hi Stephen,
I have had it wired up as per wall chart..............no joy !
I have also had it wired up to another diagram off this site.
I thought if someone had a diagram of what all the wires did coming out of the 'stalks' it would help me determine what was what.
I think I will have to get the meter out and go through all wires and try to figure out what each one does (should be fun)
Wozzer
Guest Sean Timney
Wozzer/Stephen,
Let me know the outcome, i've got the same problem...... a simple stalk colour to vg loom diagram would be great....thx
Sean
Guest Wozzer
Hi Guys,
Took the stalk into a auto electrician who identified all the wires for me........yipeee.......I now know what all the wires do.
If any one wants a copy.....send me a mail.
Wozzer
Guest Getting There
Hello
when i connected by VG to the stalks, i just used the diagram and ignored the wire coloures and it all works fine.
Mine was a 1989 and it all seems to work quite well
Chris Stubbs
Guest Wozzer
Hi All,
I have had lots of requests for this info.
Save me doing lots of individual emails I have attached it to this reply.
Please feel free to use this info
If its not correct.......dont blame me !!!!
Wozzer
Column_wiring.doc
  • 3 weeks later...
Guest Lobgob
Hi
Has anyone fitted fiesta column switches (the ones with the horn switch on the indicater stalk) to a vg loom. if so any chance of a diagram
thanks
lobgob
