Brake Master Cylinder
Stewart
Sierra bendix master cylinder put new set of rubbers in it,just put fluid in and bled it and its leaking from the piston,can anyone tell me were to get a new one fix the old one or find an alternative.
Found that the cylindere is a Lucas Part No PMH143 and guess what they are only £120 + VAT why havent I got the one off the transit they are only £30.Does anyone know why all sierra saphire cylinders on the web have the pipe connection on the opposite side"ie" on the right as you look at the piston end.
Edited by utuber
I got a new 22mm bore Bendix m/c from Popysoldshop in Norfolk - £36
I have tried them they only have ones with the pipe connections on the right looking from the pedal mine is on the left
