Speedo Cable
Going to fit ETB (7 set)gauges to Zero with a type 9 gearbox can anybody reccommend speedo cable manufacturer and provide details on ends/length/routing please?
Need cable to complete disc test.
Thank you in advance.
Regards
Mark
Are you using the cable to drive the speedo [i know this sounds daft but I have etb clocks but electric speedo ] if you know the diff ratio ETB will give you the codes for a phone call , Either Speedy Cables or Richfeild wil build cables to your spec HTH mower man :good:
Good choice ,had mine a while no probs and nice people to deal with ,I would specify the h/duty speedo pick-up the other one is a bit fragile also extra magnets they stick for agws and then 1 buggers off mower man :good:
