No Feed To Fuel Pump
balnacoul
If power for 1 second is ok (was looking for approx 6 seconds as per previous posts) then I think I may be getting too far in front of myself and thought I had a problem but the system was working as it should.
What I was trying to ensure was that, having got lights etc, I was getting power to the pump before tidying up electric bits and adding fuel into the equation. Pump did run on bench using direct feed from battery (2 second burst just to check) so system earth could be a problem, or by testing without fuel I have knacked it.
my EFI pinto pump ran for approx 1 second when ignition was turned on, prior to starting, the pumps don't like to run dry so if you have been running it for a while it may well be knackered, hopefully not.
If you're going to try running it, give it a squirt of light oil up the inlet to provide a bit of lubrication
