Wiring Loom
Guest Stephen Robertson
Hi Guys
Need your help again,
I have been wiring the igntion system and so far so good things seem to have gone smoothly, However I think I am missing some wiring from the donor. I have a VG loom and a type "c" ingintion and sub loom . Everything has connected up OK except for the coil . I have 1 Green wire From the donor sub loom
Guest Getting There
Hello
I have used the VG loom with a different ig system for an EFI, but the greem wire, does it come from the neg terminal of the coil, if so it is usually for the rev guage and will connect into the black/white wire from the VG loom.
Hope this helps
Chris Stubbs
