Recaro Seats
Guest ross
Hi Guy's/Gals (or anyone who can help)
I have a 2b and i am about to fit the seats. Iam over 6ft tall so i will be removing the runners. The problem i have is how are people securing them to the car should i just use plates underneath the bolt's to spread the load (should i end up in a hedge backwards) or do i need to run a large steel strip accross the length of the underside of the kit. Any help would be gratefull.
cheers ross
  • 3 weeks later...
Guest jetskijase
Hi All
I put a strip of 4mm 1.5inch wide steel under the car with the ends bent up so they went over the outside harness mount holes. then the larger angle between the two dedion mounts.
Then went on bill/joeys site :p and copied their idea with the two inside harness mount's ^_^ cheers guy's, this in turn attaches to the flat bar and the angle strengthing it some more.
Sorted B)
Jase
