Seat Belt Mounts
Guest Battery Bill
Guest TerryBarry
I've decided that I'm going to use the GM mounts on the supplied Recaro seats
The seats with their runners are bolted through the reinforcement angles under the floor.
However to cover my bets I'm putting brackets inside the tunnel - much as Andy suggests and I'm fitting 7/16 UNF tapped plates to the outside RHE mounting points .
I want to get through SVA - I might then look at reducing the seat height.
I've switched the seats around - I'm using the one without the height adjustment as the driver's seat.
I've removed the height adjuster on the passenger's seat and locked it out in the lowest position.
Anyway
Enough of this - back to planning the brake and fuel lines "Up the Tunnel"
Terry
