Wiring For A C20Xe Engine
Guest gazza1591
Don't have any wiring diagrams or anything but I could probably trace mine and tell you where it all goes. Is there anything specific you need to Know? Bob tucker is your man for this really hopefully he will see the post if he's about.
Guest gazza1591
Just can't get any life to the car at all? I get 12v as far as the starter motor, but nothing at the ignition barrel we'll on the battery terminal on back. Of ignition it reads 0.09v with ignition on or off
I'll have a look at mine later when it's cooled down. Just been on the rolling road. I don't have an ignition switch as I have a master switch that turns everything on and off. I have a conventional coil and the standard ignition module. Have you had it running.
Sorry, been a bit busy but I will see what I can make out tomorrow before I go out in it. Most of the loom is wrapped up in plastic piping so I don't know how much I will be able to make out. Having said that there's nothing extra on the car so that should help. The actual ignition module coil and distributor are easily accessible so I will start there and work back. It's nearly 40 degrees in my garage at the moment so I don't fancy it tonight.
Don't think I am going to be able to help much my car has been completely rewired and most of the wires are hidden inside tubing and a lot of them are one colour, red maybe live but I can't trace them individually. The ignition part of the harness is another made up piece and is all black wire. I don't really want to mess about with the harness too much as everything is finally working after being out of commission for a year. Try Google as these engines find their way into everything minis,corsas,westfield escorts and so on. Some people make new harnesses and some use the original so the info should be out there somewhere. Stick with it they are a cracking engine especially in a lightweight car like robin hood.
