Donor Car Destruction
Guest Jomeo69
Guest ScotMac
Depends which diff you have... I've seen a Quaife & an ABC in the lobro style casing.... must be just the ZF.
Surprised you've not given up on that one & gone for a quaife style or standard that don't need adjusting/servicing so often... or have you worked out a way to get it so it's easily removeable??
Dan :)
Yes, Quaife figured out how to do some type of an internal clip system. You push in the torx/c-clip flanges, and they have this spring loaded clip that engages from the pressure of pushing it in. ie, a closed diff that still allows the c-clips style flanges. As far as i know, it is only Quaife.
For the servicing, i figure the diff case is in there for LIFE on a l/w!!! ;) However, i believe i can take off the back of the case, and replace the internals, if needed....well, i can if i expand the hole in the back of the car by a *bit*.
Hmmmm....we better get back on topic....isn't this exactly the way we got in trouble w/ Mat last time we discussed this?!? ;)
Cheers, -sm
  • 3 weeks later...
