September 19, 200322 yr Hi guys I have just started my build and am currently striping down the donor (G reg 2.0GL, 205 block, weber carb), I have the VG loom in my kit . My question to you guys is where do I cut the donor loom to remove the engine bay sub loom (type C ignition ?) Cheers Stephen.
September 20, 200322 yr Stephen You should'nt need to cut it.. their should be 2 plug connectors 1xblack&white with 9 wires going into it ,and 1x brown with 6 thicker wires going into it. These feed the ignition/carb/ignition control unit/temp&oil senders The only other wires associated with the engine are the battery/starter motor. Hope this makes sense. Cheers Ian
September 20, 200322 yr Hi Stephen, After days of careful tugging, squeezing labelling and swearing, I finally got my loom out today. The connectors Ian mentioned are somewhere behind the passenger side dashboard. You may have to cut a couple of other wires though - the supplies to the heated front screen are in both bottom corners of the screen (one brown, one violet/black each side). They're more obvious if you remove the wipers and then the plastic trim piece across the bottom of the screen. The wiring on the driver's side should all pull through the firewall back into the footwell once disconnected (label it, label it again and then label the labels!). The only other problem I had is that the wiring left in the engine bay on the LHS isn't removeable until part of the brake system has been (re)moved - though I admit I haven't tried very hard yet! The fun starts when you pull the entire loom up through the hole below the fuse box. Having said that, it's just occured to me that you might be able to twist the box and pass it down through the hole sideways. Damn! Why didn't I think of that earlier? nelly
September 22, 200322 yr I tried that on my 2.0L DOHC donor and it wouldn't fit. In the end it was out with Mr Angle Grinder to cut a hole round the base of the fusebox to get it into the cockpit. This approach saves time and is much, much more fun..
September 22, 200322 yr We removed the whole of our 2ltr injection loom without cutting anything! Its easy once everything else is out. Bill and Joey
September 23, 200322 yr Thanks Guys Got it out no problem, easy when you know how. I have the VG loom so thankfully I don't have remove the whole thing! Stephen.
