Wheels
Guest Ant212
Guest Pete Jordan
Ant,
as the previous posts have stated, as long as you keep the rolling diameter and offset the same as the donor's wheels the wheels should fit. There's a really good guide called the Wheel and tyre bible on the net at:
http://www.chris-longhurst.com/carbibles
This gives you all the info you need, including what aspect ratio tyres you need to get to keep the rolling radius the same when you upsize the wheels. Hope that helps
Pete
