C20xe Redtop
Guest steve o
Hi I have a redtop that is only firing on 1 & 4 it is a distributor type( cam belt checked and rota arm ) any idears would be greatfull
What coil setup? If it's twin coil wasted spark then the problem is one of the coils is dead. Other than that check all your HT leads, plugs dizzy cap, rotor arm etc. Make sure you have everything in the correct firing order....
Any more info? How did it happen, did it just suddenly start or were you playing with it etc.
Cheers,
Dan
Guest steve o
It is a single coil set up new rota plug leads have not been played with.last sunday started and moved small amount sunday eve it just fired slightly then nothing have checked valve timing and tryed different ecu no change thanks
Guest Daniel Aldridge
Hi Steve,
Is it injection? If so remove the fuel pump fuse, foot hard down on the gas and crank for a while and hopefully it will fire up and clear it's throat so to speak,obviously not reving too high if it does fire on all four,Replace fuse and crank with a little gas and see what happens,
HTH Danny
Guest steve o
HI fuel is not a problem plenty of it going to cylinders will look into the speed sensors next trouble is is getting to it
Guest steve o
fitted new speed sensor still no change only sparking on 1&4 now maybe crank sensors?
It's the coil, this system is a "wasted spark" type, in other words, 1 + 4 will spark both at the same time, every time pistons 1 + 4 get to TDC (or thereabouts) 2 + 3 do the same, so it sounds like one side of your coil has gone by-by.
Guest steve o
the system i have is a single coil so? how does one side only work?unless it is devided else where thanks
You say you got fuel (maybe too much) and I'm assuming you have spark to all four plugs so it should fire on all four cylinders also assuming you have good compression on all four cylinders too? In a previous life I spent best part of twenty years attending customers who started their cars up and turned them off after only running for a short while and started nearly every one in the way i described,
Danny
p s I stupidly did the same thing to my tin top a few weeks ago (I should have known better) <_<
Guest steve o
You say you got fuel (maybe too much) and I'm assuming you have spark to all four plugs so it should fire on all four cylinders also assuming you have good compression on all four cylinders too? <_<
HI only have a spark on 1 & 4, compression tested and ok
Then the only things it can be now is
1/. No fuel at cylinders, are you sure 1 & 4 injectors are firing? I think the injectors fire in pairs 1&4 and 2&3
2/. Spark at wrong time (leads crossed over)
3/. Plugs braking down under compression (unlikely maybe one but not two at once)
Is it the type with the dizzy cap mounted on the end of the head with a black plastic two peice cover and held on with three scrws?
Danny
Guest steve o
With plugs out and earthed to block 1 & 4 have a healthy spark 2 & 3 do not have a spark at all,fuel getting through to all cylinders no problem, leads are corect, it is a one part cap held on with 3 screws thanks for suggestions
Sorry Steve,I ment to ask is it an orange (bosch) cap with a two peice plastic type shroud, If so it may be worth a try with the shroud removed, Easily done once the captive screws holding the cap on are removed,
Danny
