24 Volt Starter Wiring
Snapperpaul
Cables are good and thick.
I have good earths, may have a starter problem.
As i have Megajolt i should be able to reduce the cranking advance.
Thanks for all the advise, will have another look this weekend.
New engine is coming together well, just getting my head round the static compression ratio and cam choice, I have 3 available none of which are ideal but the longer the cam duration the more static compression is needed or it just wont perform, to much compression and the pistons will give up or the fuel octane will be to low.
Now reaserching Dynamic compression ratio and cam timing.
I have been to Burton Performance for some bits and have seen 2 engines marked up with 190 psi cranking pressure, I now need to know what significance that holds. If they state psi and not compression ratio it will probably have some significant's for my build.
