Fuel Tank
speedtripledan
i have the second opton.... plus points...... its big, less petrol stops ..... downside, can't use the usual fuel cap location, it would take forever to fill, just fits, the back panel would have to be removed to get it out. :huh:
I have one I no longer need, came with my 2b unfinished project, has the sierra sender already in there but never had fuel in. if you want I can measure it to see if its the one you are looking for?
If you could measure it that would be great a pic would be better still.
Dan
Allready blanked the orig fuel filler hole off now has a number plate covering it for that very reason.. cars already built so might be a problem getting it in :unsure:
Dan
Tank measures 820mm long, 180mm high and 230mm wide.
there is a hole for the filler neck opposed to an actual tube coming out of the tank as in the one above, Its stainless steel seam welded,
Hope that helps Dan
