Stoneleigh - National Kit Car Motor Show 2022 (1-2 May)
Bringing the caravan and family down for the weekend, see you there.
- Back on the scene
Type 9 box
when my type 9 destroyed its lay shaft i rebuilt mine with heavy duty lay gear bearings and changed the gearing to v6 ratios i also sourced some heavy duty synchros for it. my 242bhp 260ft lb supercharged zetec didnt break the new box ! i also fitted the a quaife ATB which is great bit of kit transformed the car.. With v6 ratios and a 3.54 diff the car would pull 65mph in 2nd gear. https://www.bearingkits.co.uk/FORD-GEARBOX-PARTS/FORD-TYPE-9-GEARBOX-PARTS/C1-10-1-0.htm best place i found for type 9 parts
EOSB 13th to 15th September 2019
What a great weekend ! Thanks to all who arranged it, we really enjoyed it. Probably see you at stoneleigh...
No problems
Are fire pits allowed ?
Just bought tickets for sue Keira and myself. Will arrive Friday evening with caravan. C u all there
2gether insurance and maybe others
Just a heads up, when buying these cheap policy's from the above and probably others, if you cancel the policy because let's say you sold your car they do not refund a single penny ! My policy was approx 2months old and her words were " there is no refund due after cancellation fees blah blah ". robbing bleeps ! I won't be using said company again for anything.... So beware peeps
- Ifor Williams ct136hd
- Supercharged SSC stylus
Thats me and kit cars done.
It took me 6yrs but I've sold the kit car, i.m done with kit cars now, after 12yrs of kit car moding and owning I've got bored of it all.... Bought a big Merc instead, 1car does it all tows the van, goes like *bleep* of a stick. Comfortable and SAFE. Have fun everybody
Just to clarify prices before I book. Myself £15, my partner sue £15 or £18? My 12yr old Keira £15 or £18 Cheers
Clutch / gearbox horrific metallic rattle and crunch
When my box did similar it was lay shaft needles and shaft had gone. Rebuilt it myself.
South Yorkshire/Derbyshire to Stoneleigh
Will be dragging the caravan down about that time. Will add to your rolling road block c u at 1130. Dan
I always dreamed of having / building a really fast car, now I’ve done it i hardly use it. I’ve done more mile’s on my mountain bike in the last 4months than I’ve done in the car all year ! So it’s time to let someone else enjoy it. I bought this car 5yrs ago as a bog standard stylus with 1800miles on and have spent 5yrs and 15k getting it to what it is today. 11000miles Spec is massive. zetec rebuilt with new main bearings, big end bearings and new oil pump. Bespoke mp62 supercharger conversion built by red7 autoengineering Ripley. Incorporating nissin gtir plenum, rx8 450cc injectors, custom inlet manifold. Twin 70mm throttle bodies. 60a denso alternator, twin belt drive one for the alternator one for the charger, electric water pump. Canems ECU Dyno.d by Dave at canems with dual maps, Map 1 is 243bhp and 256ftlb of torque. Map 2 is 130bhp great in the rain or when you have cold tyres. Flick of a switch while driving and it will go one to the other. Custom repackable stainless exhaust made by Martin Keenan (mk fame) Helix 4paddle hd clutch to handle the torque Raceline flywheel and sump Oddesey gel battery. Push button or key start. V6 type 9 rebuilt with all new bearings, Hd layshaft bearings HD synchro rings. Retro ford hydraulic clutch. Davis Craig ewp water pump and digital control. Retro ford water rail with triple core coolex alloy rad and intercooler. Mocol Remote oil filter and thermostatic oil take off and cooler. Procomp suspension all round Dotz mugello alloys with Toyo r1r tyres Willwood Midilite front calipers on 285mm vented drilled discs Rally design rear disc brake conversion 240mm discs English axle with rare 3.54 genuine ford cwp with quaife ATB diff Custom stainless 8.7gal fuel tank facet silvertop low pressure pump into swirl pot and sytec hp pump. ETB cobra white face gauges Mountney steering wheel Bespoke alloy gear stick knob and matching stalk ends. Led headlights Full weather gear Obp billet alloy pedals with willwood cylinders Cobra seats colour coded to car. mot till June. I've probably missed stuff off the list Have receipts for best part 20k This is a very quick car, not for the faint hearted! Good for 60 in the low 4,s. You can pop to the shops or blast it round a track, eat up the b roads, cruise up the motorway. Irritate bikers with its performance. It really is a sorted all round car. £10000 ovno Can email photos if interested Or will swap for hot hatch tintop ie focus st, golf/ Scirocco GTi etc
speedtripledan
