1,455 -
15
nicko last won the day on May 29
nicko had the most liked content!
About nicko
- Birthday 03/21/1968
Car type
2B Plus, 2.0i
Full name
Nick Orwin
Contact Methods
Website URL
http://
Gender
Location
Sheffield
Interests
Cars, Driving my Hood, Beer, Golf,...........
23,060 profile views
nicko's Achievements
Wheely good builder! (4/5)
167
Just for info. Mine has quite a spacious boot, and a 47 litre tank. Nick
I might pop over, but will only be going inside to get a drink. If the weather is ok that is. Nick
I may be interested if you're going Dave. I'll text you later in week(kit's blocked in at the min and I've an office/bedroom to finish. Nick
Don't believe all you see in the videos. I built mine as I described, and a couple of other people I know who built theirs have the same configuration. Things changed in the "design" over the years, but the videos didn't. I think it depends on the year of the chassis and remember it's not precision engineering (I've always said whoever welded the 2b chassis had an elastic measuring tape. Nick
The bonnet is not meant to fit to the tube behind the dash, you need to fit the dash to fill the gap. Once everything is fitted in place it is fairly rigid. Nick
When I built mine I cut the dash to fit the chassis then had to extend it to fit the gap to the bonnet. Once it's all fitted together it doesn't look too bad. Remember, you're building a Robin Hood.... If you measure everything it will look wrong!!! Fitting by eye is the way forward. Nick
I've got a red one I bought a few years ago and never fitted, I'll message you with a price. Nick
Position of bends in the rear panel on a 2B plus
nicko replied to jenson's topic in Fitting & bodywork
I could be wrong (it was 15 years ago) but I think there was a mark on the upper and lower edges of the panel that when joined with a line showed the centre of the curve. This was formed by kneeling on the panel and bending the end up and "bouncing" it to shape. HTH Nick -
Reading threads like this makes glad I have a large fuel rank and a well calibrated guage. I've never found my maximum range but I can do over 200 miles on a 3 quarters of a tank and can be confident when I hit the red I can keep going for ages.
Is the door on the wrong side? Looks to me like your holding the left door to right side of the car. I may be wrong, but worth a try. Nick
I've made a removable luggage rack for mine for strapping chairs or camping gear to, and a tow bar for either my trailer or trailer tent. I've not done any long road trips, but have driven in all weathers with not too much discomfort. Nick
Another option is Dampertech. Tell them it's for a 2b and Dave will know what you need. Nick
I built mine with the steering wheel/shaft higher than most and have plenty of room. Maybe look at lifting the steering wheel or if it was built with a tilting column it could be set low. HTH Nick
Sorted, it turns out I miss labelled some wires during the build (probably 15 years ago) and had swapped stuff round to fix. I only had to swap 2 wires over and it's all working. Nick
My bottom hose is a flexi one from a mk3 cortina. HTH Nick
