Robin Hood S7 Ford pinto 1.6 - damaged sump.
I did it on my 3A with the engine in situ. It was a bit of a fiddle but manageable.
GBS cars and coffee.
Saturday 11th. Coffee and cake at GBS HQ. Weather forecast looks good at the moment. Will pop along all being well.
14th June. GBS cars and coffee. I will pop along depending on the weather. Always good for a catch up chat and a piece of cake! Dave
Unknown fixing
Or grind the head off and push it out maybe!
Unknown fixing
It looks like some kind of rivet. Can you get access to drill it out?
Newark Kit Car Show - 21/22 September 2024
Sadly, not able to make it to Newark after all. Too many things to get sorted before going on hols.
I'm planning to be at Newark on the Saturday only this year. We're going away for a few days on Sunday. Hope to see lots of club members this year.
Material number stainless monoque?
I don't know the grade of the material but it is magnetic which means it is a ferritic stainless with a high ferrous content. It welds okay but is thin and very easy to burn through.
Side lights on 2 b
Could be as simple as a bad earth.
GBS coffee and cake.
This Saturday 15th. Hope to be there if weather is good.
Fitting cycle arches to robin hood
Due to the various RH models, there isn't a one size fits all solution. You maybe better of making your own to suit your car. Regards Dave
SVA/IVA or not?
Re Nelmo's comment above on engine emissions for MOT purposes. You have the advantage of a Q plate which means the emissions test is a visual only. As long a it's not smoking excessively you will be ok.
New mark 3, new coilovers & spring rates?
My mark 3a has inboard front suspension. I kept the original dampers but ditched the springs for 120 lbs one. Transformed the car totally. Better ride and handling. Can't remember where I got them or how much they were but well worth doing. Regards Dave
No Air Filter
Without an air filter you run the risk of dirt being sucked into the carb and the engine. If you can fit a filter somehow then you should. A simple foam type would do.
