Content Count
344 -
gomatthome last won the day on April 18 2017
gomatthome had the most liked content!
5 NeutralAbout gomatthome
Rank
Wheely good builder!
- Birthday 12/19/1957
Car type
Zero wide body 2l pinto honda fire blade carbs
Full name
Phil Wilson
Contact Methods
Website URL
http://
Gender
Location
Sheffield
Interests
Golf when get the time
8,883 profile views
Nick you obviously forgot I was keeping a set of 5 in my shed for you. phil
Nick you should have given me a call I am sure I have a full inlet manifold for my pinto when I changed over to bike carbs. If I can be of any help give me a call. Phil
This weekend stripped down cleaned and reassembled carbs. Seems to be running better but only had chance for very short burst around the block. Will try longer run over next couple of days cutting it fine but fingers crossed. phil
just remembered that the besteck electronic ignition kit included a new dissy and cap so will need to find out which one they used on my model is there any chance its out of tune? or is it still more likely that cleaning the carbs will be the solution. Have found a video on youtube showing how to clean the bowl and jets so can get on with this. Not long to go before next show so need to sort out problem as don't fancy coming in tin top. p
checked and changed hoses connecting carbs to manifold no air leaks but still no joy. as I can see 'flames' through carb with air filter off seems to suggest over fueling! It was suggested that i try replacing distributor cap and rotor arm but as the car starts ok and runs on tick over i don't think this is the problem the misfire / backfire / lack of power only present under load. In any event Andrew Page don't seem to be able to supply rotor arm and distributor caps for an E reg 2l pinto so I might have to wait till next show thats if i can get car running before then. Initially
Any roofer members out there and can recommend the best method of DIY re roofing a flat garage roof. Was looking at EPDM and Glass Fibre kits as these seem to be the two main ones suggested. Any views.
Thanks for the suggestions guys. I did have to remove carbs from inlet manifold to reattach water inlet but am sure i retightened hoses to carbs but will check again. Did not drain carbs before mothballing before christmas so will have a look it might be that any crud present was also disturbed when I removed / reconnected as above. Have filled up with fresh fuel so the little left in should have been diluted with the good stuff will try running longer to run fuel through the system. Thanks for the suggestions so far will report back on improvements. phil
Having got the car out of mothballs I find i have developed a misfire. Running Honda Fireblade carbs on my 2l pinto with Besteck electronic ignition. Having removed air filter I can see back fire into the carbs. Will start ok and run on idle but under load is when misfire starts. Have changed plugs and fitted new leads but no improvement. Any suggestions what I should look at next. Phil
they are 240 volt phil
Many thanks will check out You might be correct as my lad says when testing on the brown the tester lights up bright and when testing on the blue its dull. guess will have to pop over with my multimeter and check out voltage between both sides of fitting thanks again for suggestion. phil
A quick question for any electricians out there. My son has recently moved into a new house and in the kitchen he has downlighters one of which does not work. Looking at the wiring it would appear to be the last one on the loop as it only has one wire going into it and the others have two. Obviously changed the bulb so this is not the problem. Changed the fitting in case this was problem but again still not working. Its a standard lighting wire with blue / brown wires the earth not connected. Using a tester when the lights are switched on the brown shows power (the ligh
thanks had everything set up Thanks I think its probably too low as still bottomming out on speed bumps even at low speed might bring my spanner along to stoneleigh and adjust on site phil
Does anyone have any information on the correct (best) set up for the zero wide body suspension front and rear. phil
sorry cant mak it bonfire night and all that phil
Sorry wont be able to make it this month see everyone at next show
