Drive Shafts
speedtripledan
In general no but.......
Generally drum braked cars have the push-in splined shafts and disc braked ones have the Lobro shaft which has a flange at each end with a bunch of bolts.
It is possible to make up a hybrid shaft with one of each end but you need a specific shaft diameter and the cars they came from are a bit rare (DOHC cars with drums and Diesels from memory).
There are also a few cars out there with lobro shafts on drum brakes. These are EXTREMELY rare. They use a stub axle that goes into the drum brakes which is the same as the end of a push-in shaft but has a lobro style flange on the rear so that the Lobro shaft will bolt on.
Iain
i,ve priced it all up now £ 40 for drilled discs £14 for diff seal kit and £18 for cv boots (one shaft has split) just need to find the pads now but for the cost i,m going to get the parts and swap the lot.
Then hope 2nd gear lasts till 60ishmph 3.65 diff instead of the 3.92 thats on it now..
thanks for your replies
Dan
