Bike Carbs V Twin Webbers
Guest dellyend1
I've done the searches and trawled through all the forum info which is quite extensive and have gleened the following :
Twin Webers
Advantages
Good Sound
NO overheating issues
lots of technical support
Dis-Advantages
Unreliable
Needs lots of TLC once tuned
Poor Fuel return
Very High Purchase costs
Bike Carbs
Advantages
Low purchase cost for carbs
Reliable and stay in tune
Very good acceleration
Good Fuel Return
Dis-advantages
Need bespoke manifold and need to get angle of carbs right
potential overheating and vapourisation
Need to set up on rolling road - cost
Limited technical support
I am wanting to fit to a standard 2.0 L pinto and onto a S7 mark 3. I have heard that the full package for bike carbs from GBS can be problomatic. Is it better to buy manifold and carbs seperately ? On the face of the pros and cons I have learnt so far I think it will be the bike carb route for me. This has all come about whilst trying to source an air cleaner for the single weber carb I have at the moment. I know I will have to cut the bonnet and only want to do this once with the final solution.
I would appreciate anybody adding anything / correcting my stated assumptions to date
With Thanks
Jeremy
Guest stuart_
hi, i think you can strike overheating from bike carbs, you need to heat them to prevent freezing, which is not hard at all, the bike carbs comes with heater hoses any way, so just plumb them in.
and some carbs the angle is does not need to 100% perfect.
stuart
bike carbs all the way ! i,m bias as that is what i use. The only thing wrong with GBS carbs imho is the jetting tell them to leave alone and let the rolling road tuner set it up(every engine is different) I use there manifold and its fine, bogg bros looks nicer but don,t think its any better performance wise and it costs a lot more.
With a standard ish pinto my mains were 1.3mm blocked air correctors the car ran really well its now had a FR cam and the jets are out to 1.45mm it still runs really well as for the overheating of the carbs its happened once it was 36deg outside and i was thrashing the nuts off the car for a while, oil at 100deg water 95deg the engine was HOT as soon as it cooled a bit it was fine again once in 2yrs !
set up right on a rolling road by a good operator and they are great, trial and error then not so great.
where are you? look at my set up if you want, It works.. loads of power and torque.. and 35mpg on a steady run..
  • 3 weeks later...
Guest dellyend1
Hi All,
Having asked for advice and got really useful replies regarding Bike carbs I have looked into sourcing the manifold and carbs and have worked an approx budget of £350-£400 for the manifold, carbs, ancillaries and rolling road test. My final question is if spending this much is it really worth it ? What is the performance benefit over a standard single weber carb on my 2.0 pinto ?
I would really appreciate thoughts, opinions etc just to make sure I am spending the limited cash on the right area of the car. What I want to achieve is better / quicker acceleration in a nut shell ;)
Many Thanks
Jeremy
The differance ?? on mine it was night and day !! went from being nothing special to be being rather quick, i have done a few other things now and it is quicker still. I drive out with a friend in lotus exige before i could not keep up with him now i,m on his tail.
It was also worth nearly 4 secs a lap at barkstone sprint track.
Its all in the setup you need a dyno guy who knows classic engines and bikes to get the best from them ie torquetune near GBS a few have been to to him all with good results me included
good luck
hi
fantastic on bike carbs drives like a modern car, could not believe the difference
Paul
