2b Grill
Guest oldman
Guest oldman
Just bought a new grill from gbs for 2b are there any special fixings to secure grill to nose cone if yes where do i get them if not then what do i use cheers ray
on mine i drilled the holes in the nose cone to push the 4 bent pieces through and then i got some bits of thickish rubber and put a small hole in each and pushed it over each of the 4 bits sticking through. The rubber grips tight enough that it won't allow the grill to fall out and i can just pull them off if i need to take the grill off
hth
