Double Wishbones
Guest simonb
Hi Guys,
Haven't posted for a while as have been rebuilding engine. I'm having a bit of trouble seeing how to fit the upper/lower wishbones to my 2B plus. There are 4 right-angle brackets in the kit so do I need to weld these on?
I would have thought that these would come pre-welded considering the difference in price of the 2B plus and the std 2B kit, and the videos don't really go into any detail on the subject. :(
If someone could post a picture of how the rear of the wishbones attach, I would be most greatful (and buy them some beer when the cars finished). :D
Guest MikeD318
Simon,
The right angle brackets are bolted on to the chassis behind the right angle pieces. You can weld them on if you want but I would suggest bolting them initially (just in case it goes a bit pear shaped), you'll also need to space it out with washers too. If you pm your e-mail address to me, I'll send you a photo so you can see what I mean.
Mike.
Guest simonb
Cheers mike - have pm'd email address. I thought that all suspension mounts etc had to be welded for SVA?
Guest MikeD318
It says bolt them in place on my videos. I have used ht bolts anyway.
Mike.
Guest TerryBarry
Hi Simon,
Here's a pic of the bottom wishbone mounting
I'll see what I've got re' the upper one - but once it's in position you need a fibre optic system to photograph the dumb thing.
HTH
Terry
Guest TerryBarry
Here's the upper arm - but the bracket is hiding behind the square tube where the upper shocker mount goes.
Terry
Guest TerryBarry
If you want to see a pic of the bracket - after modification have a look at Steve Loat's website Steve Loat
Under "Build Diary" go to "Jan 2002" then down to "Jan 12th".
Terry
