Guest Brian T
I've been looking around for Weber 32/36 servicing hints and tips . Found a great article ,complete with photos, so I thought I'd add a link just in case anyone else needs it in future.
http://www.classicfo...CLF140.dgv_.pdf
Hope it's of help to someone at some stage.
Hi Brian T,
I have the same problem as Kev. My car has a Ford DOHC Engine from a Sierra Sapphire and is fitted with a
Weber Carburettor is a TLDM, the exact model will be 2630 W on top plate of Carburettor Weber 25-23
stamped on the float bowl 28 32 TLDM on the outside. I too would be interested on any info on this carburettor. I have a book from the Library on Weber Carbs and it has totally confused me ( which is easy to do!!)
Appreciate any detail Cheers
Steve
Guest big kev
Hi Brian T,
Steve
Steve I have a Hayes manual for ford carbs with our carb init. Once ive serviced mine I'll happily lend it you if you want!!!
Hi Kev,
I assume it is you? that is offering to Loan out your Haynes Manual, I have borrowed from the Local Library a Ford Vehicle Carburettors Repair & Service Manual book that covers Ford, Pierburg, Solex, Weber 1978 to 1991 ISBN 1 85010 783 1 If your book is the same I will be able to use the info from the Library Book rather than worry you for your copy.
Thank you for your kindness. Appreciate your kind response.
Regards
Steve
